Scott Will
Back when I was designing the panel, I thought about a map holder but didn't really find the Van's map box feasible for me.
In searching for a place to put my charts, registration and other 'stuff' I made this little contraption. Today I got to install it in the plane for the first time while the winds were howling. It installs on the spar channel cover and the vertical support just ahead of it. Note, I installed about 8 nutplates on the spar channel cover so I could add some map lights. That way I can remove the front face and gain access to the stuff buried in that channel. Works pretty good although I'll probably remake it so that it is deeper and then the charts will fit a little better. That longeron is messing with the charts sitting nicely against the skin.
I'm also going to add a place to put my mp3 player on it as well as the Lightspeed headset controller. That wire you see hanging near the key switch is the 3.5mm input for aux music.
![p1020463.jpg](/proxy.php?image=http%3A%2F%2Fscott.jpainter.org%2Flog%2Fimg%2Fp1020463.jpg&hash=20553a5c1388b7f07b598a044844d0ef)
![p1020466.jpg](/proxy.php?image=http%3A%2F%2Fscott.jpainter.org%2Flog%2Fimg%2Fp1020466.jpg&hash=7ae4fe8b34224cde758d1fe43fe19bdc)
