I thought that I would pass along a learning for the community. I purchased a used kit partially built. The P/O had installed the wing tips and I needed to take them off for inspection and painting. He used #4 Brass screws with Phillips heads. Many of the screws were pretty tight and I stripped a few heads with one having to be drilled out.
I plan to replace with stainless Torx head screws. Torx doesn't require the pressure that phillips does and you are pressing against thin aluminum sheet with no backing. Further, the brass in a #4 strips very easily.
Good luck,
Larry
Good luck,
Larry
