Talking to a Cozy/longeze/berkuit builder assist guy near me he showed me some stuff made by Evercoat called Polyester Glazing Compound. It is easy to work with, sands pretty easily and seems to go a good job on filling pin holes and other areas that need filler. It is a two part polyester, not to thick, easy to mix and trowel on. It starts to kick off in about two minutes and gives you about 7 minutes work time, so small batches is the way to go. Sandable in under 15 minutes. Evercoat has a new product as well that is supposed to be better called Quantum, but haven't found that yet and it's quite a bit more expensive.
jjet
jjet
