Tip: Avionics Upgrades - Planning is the Key
Ironflight
VAF Moderator / Line Boy
Mentor
Ask any successful military leader – no matter how well you can execute, a battle is generally won or lost in the planning stages. The same is true when planning an avionics upgrade (or initial installation for that matter, but that is a slightly larger topic), so I thought I’d share a little of the planning I am doing for a minor set of panel changes I have coming up. I estimate that the actual work will take a few days – the planning will, by the time I start, have consumed probably twice the number of hours. That’s a good ratio to think about when considering a project of this sort.
In this case, I am going to be upgrading my Grand Rapids EFIS system from a Single HX, Single HS, Single AHRS to a Dual HX, Dual AHRS system. Simply put, I will replace the single AHRS with a Dual, and the HS Display with an HX. The DU is ALMOST plug and Play (it would be if not for an internal GPS I have installed), and the AHRS requires a little additional serial (RS-232) wiring plus the installation of a second Magnetometer. Since I have the RAIM GPS module on the HS display, and it won’t plug in to the HX (without an external adapter), I’ll wire up my 696 as “GPS 2” for the overall system – been meaning to add that as an additional option anyway. In addition to this project, I am going to upgrade my Tru Trak Pictorial Pilot/Altrak to a Digitrak II VSGV. This means changing the control head and pitch servo, as well as removing the Altrak control box and push button/light. Since I have the Altrak controller in the back of the airplane near the servo, it means running some new servo wire all the way back behind the baggage compartment from the panel. Since adding the additional Magnetometer also means about six new conductors taking the same route, it makes sense to do the two upgrades at the same time. Since I’ll take the panel out to add the serial connections, that makes it super easy to do the additional autopilot wiring then as well.
That paragraph (above) is the culmination of the first part of the planning – figuring out the broad strokes of the project. I could do the two at different times, but that would require opening up the whole cabin and reclosing it twice. I could elect to do one or the other now, and only run additional wiring at this time, then hook up boxes later – but doing it at one time makes sense if I can afford it. I can do all the check-outs at once, and the airplane will be out of service less time. (Since the interior has to come out for the annual Condition Inspection now anyway – it’s a three-way winner!) Coming up with the conceptual plan for the upgrade involved requirements definitions, looking at what played well together, what was available, and what we could afford. It involved a little perusing of the manuals to understand the interconnections between the various boxes, and looking at such things as dimensions, panel layout issues (there aren’t any), and what to do with the empty hole where the Altrak button is now (still not sure, but I’ll come up with something…)
Armed with this overall plan, the next step was getting the hardware ordered and enroute – then once the reality had sunk in that equipment was on the way and work will actually begin in a short time, detailed planning was in order! One of the most awesome things about the modern experimental avionics market is the fact that almost everyone’s manuals are online. That gives me instant access to wiring diagrams, wire lists, pin numbers – and better than all that, installation plans for various avionics combinations. I salute all the manufacturers who recognize that their equipment is going to be used with the equipment from other manufacturers to build a system, and have already developed detailed drawings for how an installer can set things up to make them work. In my case, GRT and Tru Trak have drawings that show how to hook up exactly the system I am building with the Garmin 430 that I have had in the airplane all along. Since I already have the wiring drawings for the system as it is installed today, it was simply a matter of looking at the changes between the two configurations and building a DETAILED list of new interconnects that I have to make.
Note the emphasis on the word DETAILED. That is the key. Long before I pull the panel apart, or even open the boxes as they arrive, I should know, wire for wire, what I need to do to achieve a given configuration. Without this knowledge, you’ll find yourself working in the blind, stumbling along at the workbench until you figure out that you don’t have enough D-Sub pins, or that Male 9-pin shell you thought you had has disappeared (oh yeah, you used it on another project months ago!). Planning includes getting ALL the resources lined up – including wire stock, heat shrink, back shells, cable clamps – everything that you need to install the project without having to stop and order something. Only by developing a detailed plan can you anticipate these needs.
In this case, here is how I documented the work needed for this project. I simply built a “wire change” list That starts like this:
Dual AHRS Install
Wire AHRS 2 to DU 1:
DU 1 Connector A - Pin 24 to AHRS 2 Pin 03 (AHRS 2 Input to DU1 - Serial 6)
Wire AHRS 2 to DU 2:
DU 2 Connector A – Pin 4 to AHRS 2 Pin 05 (DU Output to AHRS 2 – Serial 4)
DU 2 Connector A – Pin 19 to AHRS 2 Pin 01 ( AHRS 2 Input to DU 2 – Serial 2)
Wire AHRS 2 to Mag 2:
AHRS 2 Pin 7 – Mag 2 Pin 2 (Z)
AHRS 2 Pin 8 – Mag 2 Pin 1 (Y)
AHRS 2 Pin 9 – Mag 2 Pin 3 (X)
AHRS 2 Pin 14 – Mag 2 Pin 5 (GND)
AHRS 2 Pin 18 – Mag 2 Pin 6 (CNTL)
AHRS 2 Pin 22 – Mag 2 Pin 4 (Power)
[And So on.....]
I build this list for each and every connection that has to be made or changed, researching the contents by looking in the manuals and drawings. Identifying connector and pin numbers at your desk and writing them all down will pay off when you get in the shop – you’re less likely to make a mistake if you have done your research and checked the work over. Doing this detailed review will ensure that what you plan is actually feasible, and will identify any “gotcha’s” in your plan. In addition to this wiring list, you can do just as detailed list of the wires that need to be dragged through the fuselage, and where they have to go.
There are several other things you can put in to your “pre-battle-plan”. Will you need hardware for mounting anything? Raw material for fabricating brackets? Are there drawings out there that will allow you to pre-fab the brackets? Will you need to upgrade or add circuit protection? How about cooling? Once you get that UPS shipping notice, the clock is ticking – and you can’t play with the new toys until they are fully installed, so get to work early and be ready to storm the castle!
Paul
Gracias
Thanks for posting your planning process Paul. I expect that I will do a similar upgrade in my bird soon, WS to HX and single to dual AHRS. Also planning on resorting the ergonomics, nothing like flying a panel to know what you want to change.
Hans
Ask any successful military leader ? no matter how well you can execute, a battle is generally won or lost in the planning stages.
Paul
And most plans don't survive the first bullet fired! ;)
Seriously, great write-up, thanks for putting it down on paper, er, uh, you know what I mean.
"Have fun storming the castle!"
Joe
Upgrading to Duel HX'S & VSGV
You will love them when you finish.
I did the Duel HX Duel AHRS upgrade last year and already had a Digiflight II VSGV plus a third GRT 6.5" HS sport for engine monitor in my RV-10. Having the duel screen HX's with one on the PFD & SV and the other on the moving map with terrain and weather is really nice.
Looks sorta like this, huh?;) (not much in the way of terrain, but lots of water!)
I installed the second HX (in place of the HS) yesterday - waiting on a few bits and pieces (wires, pins, etc) and the Tru trak before doing the Dual AHRS upgrade - week hopefully!
abuzz with questions
That is a very exciting photo Paul. And thanks for the pep talk on planning.
I've been thinking of HS-> HX, but I'm still at the HS on the desk part of things. The planning I started for two HX's showed it would be tight.
What issues did you have with the clearances and mounting?
Did you use the angle-up mounting rails idea for the lower HX?
What is the stick clearance now?
Any chance of unplanned button activation for stick forward?
I don't remember if you had the stock or bent stick?
I'll be fine with the interconnections, but I'm very interested in the mechanical/mounting issues.
Since the HX and HS have identical faces, the change from HS/HX to HX/HX didn't change anything mechanically (except that the HX is less deep than the HS, so I have a little more rear clearance). Likewise, the wedge doesn't really change stick clearance, since the bottom of the lower unit is actually higher the farther aft you go. If the stick is short enough to fit under the panel, you'll have no problems - the HX/HX stack does not extend below the panel. And yes, I do have a bent stick from Todd...
Paul
A call to GRT/Carlos straightened me out- both HS and HX are available in the 6.5 and 8.4 formats. I'd got it wrong, and thought the HX was in the 8.4 format only.
Looks like the vertical arrangement in an RV-8 is limited to the 6.5's.
Thanks for your time, and the great examples you set.
Paul,
Does your 696 play any roll in your new panel? I am currently flying a VFR only panel with my 696 mounted front and center in the panel. Looking forward to installing a GRT Sport in the Spring and was wondering what interaction if any there could/would be between the 696 and Sport. Do you propogate flight plans between your GRT, 430 and 696?
Paul,
Not at this time. I have the 430 and GRT RAIM GPS drivign the EFIS and autopilot. Next time I open up the right side of the airplane, I might wire in the 696, but it is not a priority since I can't ship flight plans IN to the 430 anyway.
Paul
they play nice together
Steve - The 430, GRT HX, and 696 play pretty well together. I have that combo in my panel, and I have it working on the ground. I should be doing my first flight any day now and can report better then. I don't know how different the Sport and HX are as far as inputs/outputs, so YMMV.
There are some limitations on how they talk, though. To the best of my understanding, you'll have to decide on the 696 input because it can only take one data input. I have a 330 transponder and had to decide between showing traffic on the 696 or getting the flight plan from the 430. I chose flight plan because traffic will be on the 430, and I'd like to use my 696 as a backup GPS. If the lights go out or flicker, I want immediate access to my flight plan on the 696. Also, the 696 has some very nice flight planning tools that the 430 doesn't have. I did, however, install a switch behind the panel to allow me to easily (on the ground) switch to traffic on the 696 in the future if that's the way I decide to go.
I didn't do this, but another consideration to think about if you have an autopilot is an input switch for the AP. The GRT drives a TT autopilot very nicely and gives you some performance not otherwise available from the AP. But a simple switch will allow you to have the 430 drive the AP directly (bypassing the GRT) if anything should happen to the GRT in flight. If you're VFR only, I wouldn't worry about it. But IFR, it's a nice option to have.
