msturgis
Well I knew there was a good reason I was nervous about drilling the trailing edge on my rudder.
I used a piece of aluminum angle clamped to my workbench, then drilled/clecoed the trailing edge to the angle. I starting drilling at an angle using a cardbord square for the first couple of holes. Then using the cleco next to the hole to be drilled to set the angle.
Once I was done everything looked great......... Until I flipped the rudder over. I noticed about half of the holes in the skin were oval shaped. It seems I used to much of an angle and enlarged them.
I plan on calling Van's tomorrow, but i'm guessing I need to order a whole new skin.. Any one ever had this problem, and if so were you able to salvage it?
