In my 9A, I'm installing the flaps and the bar is really tight, even with the center support unbolted.
Best way to fix that? Can I sand the white support blocks?
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Dkb
Dkb
My flap bar came with the center 2" or so unpainted ... that is, no powder coat at all. It fits and pivots perfectly. I suspect it would be very snug with a coat of powder paint in that area.
Bar is clear and burr free. Also, the ends and center seem to have a slick Silicone like solid black material. I assume it was a factory material to help with movement. I did not want to sand THAT away. Am I missing something?
Be sure and check the ends of the bar, mine had some burrs around the entire circumference. It appeared they were cut with a pipe cutter, a few seconds on the scotchbrite wheel and they were not tight anymore.
Greg,
That was the center rudder control support where the washers were shown.
I don't believe the outside rudder control support or the flap delrin get this treatment. Also I think the center rudder support is the only one that gets cut in half. I believe the block are snug by hand but with the leverage of the flap control it is a good snug.
