Hi All,
Quick question on the washers used for the AN3-7A Bolts that connect the tie down assembly to the wing. The instructions list the bolt, nut, and 2 AN960 washers (an AN960-10 and an AN960-10L washer). Question is, which side does the 10L washer go on. Under the Bolt head or under the nut?
Aslo, the 10L is the thinner washer correct?
thanks
thanks
