The RV 12 is very light on the nose with a full tank of fuel. I have had it tied down outside this winter and have had the aircraft come down on the tail twice. This caused some damage to the stab trim and rudder. The rudder lock was knocked loose also both times. I now use a tail post made from 1 1/4 inch dia PVC pipe 33 in long. Cut a slot in the top to fit around the tail tie-down fitting with a bolt through the fitting to keep it in place. With the tail also tied down it keeps the aircraft more secure. I hope this prevents someone else from experiencing similar damage.
Jake - N124JT
Jake - N124JT
