Tie Down fitting ideas
jcbarker
I've been noodling over a couple of alternate solutions to the steel tie down ring called out in the plans. As been noted in another thread, these are not included in the kit.
Here's a couple of ideas:
Off the top of my head: the removable 1st iteration will - lose the screw and be a pain to install (how to tighten the screw?) #2: the fairings with screw attach will get lost ASAP :(
Maybe just polish some standard stainless steel eye bolts and screw 'em out when you don't want them hanging out in the wind? Or maybe a spring loaded "cargo tie-down" plate/ring - it may be a little draggy, but nothing to remove.
I tried fitting a retractable ring tie down a la a 182 against the wing spar but it would require an entire new inspection panel.
And use something similar to a bumper clip (URL="https://www.amazon.com/Fender-Bumper-Shield-Clips-....) when flying
I have a roll of white 2" wide vinyl tape (the kind used by glider pilots for anchoring gap seals). It's ideal for covering up holes like the ones left when you remove your tiedown rings. It stays on till you remove it. And, 1 roll has lasted me 4+ years and is still not run out.
I'll bet its easier to remove than those plastic clips! ;-)
tie down holes
I know this probably sounds super ignorant on my part. But what is the reason for covering up or filling the holes when the tie down rings are removed?
To reduce drag and help prevent water intrusion. Whether it really makes a difference on your typical RV may be debatable. But hey, every little bit helps, right?
Perhaps. Still I'm not seeing how a hole on the underside (as opposed to the top) of the wings creates any perceptible drag. And water is more likely to drip down than drip up.
Cheers, Ken
Get the Cleveland tool ones..
I have the slick ones from Cleveland tool also, and they are usually stashed in my on board gig bag that also has short loops of robust small gauge rope attached to them. That way, when you end up at an airport with big fat frayed ropes that don't fit through small rings, you can still tie off to the nice small rope loops. If you align these nice fittings with the large diameter holes in line with the airstream, the drag is nill anyway, and they can be left in all the time (Minus the mentioned loops), barely visible to most.
Hey everyone:
The idea was to have a decent looking tie down fitting that you wouldn't need to remove. Extra drag? Yes. Measurable? Don't think so.
Will they double as jack points?
Something to consider.
I have the tall HF bottle jack thingie with a scooped-out ram end, and use acorn nuts on threaded shafts as jack points - these look like they might do double-duty.
I just used my jack last week to perform a pre-paint job W&B, and if paint goes on as hoped this weekend, will be able to answer the age-old question about how much a paint job adds to the empty weight of an RV-10 and how it shifts the empty CG.
Note too that on every RV I've seen, that there is about a 1/8" gap between the bottom skin and the threaded tiedown bracket that's bolted to the spar. If you tighten the tiedown ring under the wing too much, you end up with a large ugly dimple in the skin.
Nicely done Carl!
Do you know what the diameter of the large hole is in the stainless fitting?
Also: Cleaveland says they are out of stock.
I'm always bemused when people spend time and money and often add weight redesigning something that works nicely as-is.
The Cleaveland tie down ring is fine if you use a carabiner with it. With rope, the sharp edge will considerably weaken the rope under load. Rope is sensitive to stress concentrations just like aluminum is.
Dave
Tiedown ring drag; hole drag; Whaaaaaaat??
Dave
Agreed and agreed. My (stock Van's) tie down rings are in my tool bag along with my control locks (VERY small and simple) and chocks. It takes me probably 10 seconds each to screw the rings in. I would imagine an unfilled hole causes some drag but would likely be measured in picograms of resistance. :cool:
Mud daubers love it up in there - so go ahead and leave it open. Give a bug(s) a home.
Our Airplane
Here’s what I did on the wingtips or our RV-6 after my local RV pals gave me grief for leaving the eyebolts under the wings. Besides, the tiedown rope or chain on the left usually fouls on the pitot tube. If folks really want me to, I’ll remove the wingtip and take a couple more photos.
That’s slick!! Yeah show some details..
I've flown with and without the tie down rings installed and can't see any difference in speed or handling. So I usually just leave them on.
Jerry:
I like it! :cool:
But what to do with the Mud Dauber Hotel? Oh, I know, a 3/16-18 stainless set screw with a little locktite. ;)
See post #18 about tight radii on tiedown fittings.
Dave
I installed two of these and love them. I get many complements on how nice they look and how they don't create much drag. They ate well worth the money in my mind!
There are numerous ties downs mentioned in this thread.
Which "these" did you install?
Photos, Phinally
Aw, man. I goofed up the photos… here are the correct ones. Sorry for the mess! So here’s how I did it. I scored a piece of .125” 7075-T6 at the local metal supply for the pivoting ring thingy. I’m sure 2024-T3 would be fine. The rest is simple sheet metal work and mostly AN hardware. There’s a 5/16” OD bushing on the pivot that the bolt tightens down on. I made up a couple of nylon washers to take the side loads. The spring is inelegant and I’d envisioned bending up a clock-type spring to install coaxial with the pivot, but I ran out of time. One of these days I’ll fix that. My CFI wife says it’s her favorite thing about the airplane. BTW, I spent a fair bit of time pondering this and came up with a number of bad ideas. This was finally was inspired by the tiedowns at the upper end of some of the Cessna struts, and locating them on the wingtips copies the Grumman single engine airplanes. They clear the pitot and they’re easier to reach. I just left the existing holes in the bottom of the wing as they are. This airplane is hangared so we don’t have problems with mud daubers, but if I go out of town of course I tape the holes. If I ever do another set, I’ll at least move the bolts a bit further apart so I wouldn’t need to trim those AN960 large area washers. If ya’ll have other ideas or refinements, I’d love to hear about them. Thanks for the interest!
Not a structural engineer, but I would be concerned with those alum rings. It looks like 1/8 X 3/16" at the thinnest point. I struggle to see how aluminum of that size could hold up to the loads imparted during a strong blow from a T storm. The plans use 3/8" dia steel, threaded into a .5 X .5 X 6" chunk of alum bolted directly to the thick part of the spar. At least they did on the 6 and the 10; cant speak to the 14. Hard to tell from the pics, but look like it is using thin support material rivetted to a thin wing rib, possibly tied into the thin spar flange. This appears WAY less structurally sound than what Vans designed. Certainly not saying it won't hold, just saying that it seems substantially under engineered comparied to the original design.
I may have not fully understood your intent. Possibly you use the stock tie down rings in strong winds and these are just for burger runs in good wx. In that case, it is a neat approach. I just leave the rings in the tool bag and install them when tying down away from home when chocks alone are inadequate.
Larry
On the RV-3B, which sits very low to the ground, I was concerned about the sharp angle that the tiedown ropes made to the wing. That increases the load on the rope. Being a structural engineer, I looked at the loads if the tiedown points were located at the outboard end of the spar, and found that while the tiedown loads were reduced for the rope, they were too high for the spar; the spar might buckle, in spite of the rope's tension load. Your plane, with different geometry, might not have that problem. But it could still be a concern and you should check that.
It appears as if your tiedown ring is parallel to the airflow. If that's the case, it will be susceptible to the sideload since tie down ropes usually angle outboard to the wing in use. It could have bending loads high enough to cause problems on the ring even if the spar is okay. Another thing that you should check - ideally the ring will be parallel to the spar.
Dave
Like it a lot
I like these a lot. I have seen something similar on a sailplane, why back when. We have short wingspans as compared to most other planes. Being at the wing tips seems like it will be easier to tie up. I wish someone would make a retrofit kit.
The 7075 alloy is a good choice; nearly as strong as steel.
I see this being incorporated by the factory into the RV 15, (just saying)
Anyone, anyone, Bueller, anyone?
Edit: See later post by factory; this may be one instance where That Looks About Right engineering may not be the best. I will stick with factory
I'm looking at tie-down ring options and I was surprised to find that my -7 QB wings are threaded for 5/16" bolts so the rings from Van's and Cleaveland won't fit.
Tie down thread
That's very odd. Vans has used 3/8 for quite a while.
I wonder why it changed?
Check McMaster
Not sure what kind of Mud Daubers you have in California, but the ones in Texas build inside hangars.
I’m sure everyone knows this already, but I didn’t.
At least on the RV-8, there are threaded spots in the baggage compartment for the tie down rings. I assume this is so they can do double duty to secure loose baggage during flight, then the airplane on the ground!
I wonder if someone tapped them 5/16 and don’t have full thread engagement? Or possibly used Helicoils to bring them down to that size? Either way, that’s odd..
I agree with Larry.
There is a reason that the tie down anchors on RV's are designed the way they are.
The small cross section area of the small rings will be way deficient by comparison.
Keep in mind that when you really need a tie down to work, the load imparted can be quite high.
Should have said so in your first post.
Anyway, here is a fairing set designed to be used with the Cleaveland tie down rings I linked in my Post #4. Easy on and off.
https://www.rvplasticparts.com/product-page/tie-down-fairing-set
I have those Cleaveland tie downs and leave them on all the time. If it had been me, I'd have been just as happy with the rings. I did remove the Cleaveland item from the tail and replaced it with a ring in order to mount a Go Pro.
If I ever need to jack up the airplane such as at condition inspection, I replace the wing tie-downs with some grade 5 carriage bolts to use as jack points.
The previous owner of my plane apparently knew Scott Melton here and put on a pair of those, as well as other 3-D printed items. I have similar fairings for the sump drains, and fairings for the flap struts. They're secure, but don't really take paint well and look a little rough.
No clue about the aerodynamic effects of the Cleaveland tie downs and the 3-D fairings. I'm sure that there's no downside, not sure if there's any benefit.
....Keep in mind that when you really need a tie down to work, the load imparted can be quite high.
When I determined that wingtip tiedowns could overload the spar on an RV-3B, I was using 70 mph winds to assess that. Remember, that's based on RV-3B geometry which differs a bit from the other RVs. But the 70 mph is roughly what was encountered at Sun N Fun not that long ago, and LESS than I've personally experienced at Boulder, CO in '81, standing next to my C170, which was tied down.
Loads can indeed be quite high.
Dave
we made ours out of stainless, serves as a tie down and a jack point.
I ordered two titanium threaded ring bolts with the right threads, cut it to length, put a rubber washer on to protect the paint and just leave them on. Saved weight and increased bragging rights.
Why not grind some of the trailing edge off and make it the classic tear drop pressure recovery shape?
As robust as the standard Vans rings are, I think they would still be sufficiently strong enough to do their job.
That’s what my plan is and I plan to leave them in place. I don’t like the idea of wear on the aluminum threads from the steel threads that would occur over time from repeated insertion/removal or an invitation to mud daubers.
As a bonus, if a person could find some type of rubber wheel shaped like a tire rim to leave in place when not in use, it would look and act like wheel pants. Or even two buttons that could be easily separated by using something like magnets. Make each button from 2 hole saw circles. One to cover and one slightly smaller to prevent movement. JB Weld a button magnet on one side and washer stack on the other. When needed, easy to remove.
It would be a 9 to 1 reduction in drag if you use the round to teardrop methodology. Hey, a speed mod!
