Wesflies
Active Member
I have started working on the tie-down assembly for my left wing on a 7A. The plans call for AN3 bolts to attach the tie-down bar to the wing spar. The pre-drilled holes in the spar that will accept the AN3 bolts are almost AN4 size. Has anyone else noticed this? Is it a problem or should I just keep building? Thanx, Wesflies
