Having worked on PCs for the last 25 years I have learned to hate the little screws that are used to fasten db connectors to the back of computers. Fortunately, most cable manufacturers have gone to using thumb screws so a screw driver is not required. Until GRT, Trutrak, and others!! ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After two false starts I have finally found a supplier and the thumb screw that will fit most all the plastic db hoods provided by GRT, Trutrak, and others. (By the way, Approach Systems uses hoods with very nice thumb screws.
You may not care BUT IF YOU DO here is the link to the part. 50 of them will cost you 12.50 plus frt. ($6.10) and tax ($1.07) to 35010.
Allied Electronics, Inc. Stock No. is 810-0009. Link to page follows:
https://www.alliedelec.com/Search/P...SC=B71E014276&R=810-0009&sid=479D1B001E0BE17F
RV7 Wiring/Plumbing
Eggenfellner Subaru E6T on firewall
N808AF reserved
256-329-2001
RV7 Wiring/Plumbing
N808AF reserved
256-329-2001
