pilotkms
I had to replace the throttle lever on my Precision Airmotive Fuel Injection servo because the originally provided one was too short. This new lever has a 1/4" hole to attach to the cable bearing. The Vans supplied bearing is MW-3M with a number 10 hole for both the lever and the cable threaded end. I have not been able to find a bearing that will fit this > 1/4" inch lever hole with a number 10 cable threaded hole. Anyone know of one?
If there isnt one can i use a piece of brass tubing and make a bushing for the AN3 bolt that goes thru 1/4" hole into the the MW-3M ?
