walkman
I have the more or less standard 3 level throttle quadrant in my RV-8. It looks like the ACS one, but I did not build this airplane.
Recently I replaced the throttle and mixture cables which had become very stiff.
Now I realize the new cables are too smooth! They creep around in flight. The biggest culprit is actually the cable I didn't replace - the prop control. I did disconnect and reconnect this cable, and relocated an Adel clamp during the process.
The throttle quadrant has a black plastic thumbscrew on it which I assume is intended to be an adjustable drag/lock on the controls. It appears to have no effect.
How is this supposed to work? Are there washers or spacers that may have gone missing?
