CharlieWaffles
So to be clear, this question is about the THROW length of the throttle cable, not the overall cable length itself. I just ran a stock vans throttle cable to my stock YIO and the overall length appears ok, but there doesn't seem to be enough through on the quadrant side of things. The stock 2" throw does move the throttle body control through the full motion, but the rod end bearing has to be only about 10 twists on. The throttle quadrant seems to be unable to get full deflection from Open to Close. It seems I have about an inch or inch and half of linear travel on the face of the quadrant I can't use. So I'm think I need a 2.5" or 3" throw to get it to work properly.
Has anyone else done anything like this or do you just live with the partial deflection on the quadrant?
