All,
I was installing the carb and throttle/mixture bracket tonight on my Lyco O-360. I tightened the nuts that hold everything to the engine as much as I dare and there are still no threads coming all the way through. They are about even with the bottom of the nut.
There is a washer and a lock washer between the nut and the bracket. Should I remove the washer and just go with the lock washer? I am not sure that will even give me enough thread showing.
Comments/suggestions appreciated.
