I was not happy with how my deluxe quadrant feels. The arm tends to slightly bind in the aluminum slot. I commissioned a quadrant from Baxter that has a trim switch built in. The actual lever is 1/4 inch square with the wire running inside.
When I went to install this, I figured out that the standard throttle cable has a 10-32 threaded end. I cannot seem to locate a terminal end AN665 or similar that has a 1/4 opening and a 10-32 threaded female side. I can find it with a 1/4-28 but don't know how to reduce that without a major disturbance of the geometry of the control. Anyone run into this?
