I need suggestions from experienced RV3 builders regarding throttle cable routing. The problem I have is the quadrant is on the left fuse wall and the throttle plate arm is on the right of the carb. The RV3 mount is soooo close to the firewall that turning the corner to the throttle arm is VERY tight !!! Any suggestions ??
