EXP119 folks:
I got the throttle cable connected ok, but I am wondering if the fore and aft adjustment is correct. I put the throttle at 50% at the throttle body and the pulled the cable out from the panel 50%, connected it at the helm joint. This will work, but the fore and aft adjustment screw is at it's max travel. I would feel better if it were more centered. Does this seem correct?
![Cable Throttle threads at max.jpg Cable Throttle threads at max.jpg](https://vansairforce.net/data/attachments/19/19907-9db2399c644a3fed5b9048babafd7513.jpg)
