bweiss
I am installing the throttle body for a precision fuel injection (vertical induction) on an RV7A and I several questions based upon the following observations.
A The bracket appears to only hold the throttle cable and the cable is about 3.5 inches too short
B. The mixture cable also appears short and does not have anyplace to hold it secure
Is there a special bracket that I have to install as opposed to the standard Carb version supplied by Van. I was under the impression that the carb bracket fit the vertical induction FI system?
Where is the recommended firewall pass through for the mixture control?
Did anyone else have to lengthen both the throttle and mixture cables?
