1. Reed Switches: I like to test continuity and function whenever possible when installing electrics. I cannot get either one to register a completed circuit (continuity) when the magnet-loaded pins are swung into position. What am I doing wrong?
2. Grommet Overload: There is no way the static line is going to pass through the grommet in bulkhead #3. I have only the plans-directed wires there. What's the fix?
3. Aft 9-pin D-sub Connector: Plans show this mounted up on the bulkhead just aft of baggage bulkhead. There is no receptacle. Is this connector just tie-wrapped in position? This seems questionable given stabilator cables back there.
I've read through this section of the plans but it wouldn't be the first time some obvious solution eluded me. Directions to chapter & verse in the plans or successful-builder fixes will be much appreciated. TIA Jim
