LIMA HOTEL
Active Member
In your "READ THIS BEFORE INSTALLING AVIONICS" sheet that came with the Garmin equipment, switch panel,& and harnesses, item no.4 states that the transponder (GTX 327) is already configured to communicate with the other avionics. Did you also set up the Automated Airborne Determination so that the xpdr goes from standby to ALT at liftoff and returns to STBY when back on the ground? Also how is the flight timer set up; is it set for MANUAL, ACCUMULATE, or CLEAR? The pilot guide, which is all that came with my unit, (no installation or set up guide) states that these items are "dependent upon installation configuration". Should I have received an installation guide so that I can configure these myself? These are really useful items that I intend to use.
Larry
Larry
