Threading Wiring thru the Stick
Alschief
While trying to fish a pull wire Thru the control sticks, we were not having much luck. Then I remembered a trick that Electricians use.
Found some heavy string, placed it loosely in one end. Attached a vacuum cleaner to the other end. The string pulled Through in a second, ready to pull the COM wires.
Now if we just had the missing sub-kit.
