Threaded drill bit help
Jamie Aust
Hi All.
Some time ago I got some threaded drill bits from The Yard Store and Avery. At the time I didnt have the Angle drill as I was going to use a friends. These are all 1/4 28 thread. I have now, a used angle drill, but the bits I have are loose in the drill chuck. The diameter of the threaded end ( drill chuck) is bigger than the drill bits I have.
I dont seem to be able to find any ref to Diameter to order some sort of adaptor to fit inside my angle drill to change down to the size bits I have.
Any help would be great.
The drill you have is threaded 5/16-24 (I think). One size up from 1/4-28. I also have an angle drill that size but alas no bits. If anybody knows where I can get 5/16-24 threaded drills, I would love to hear from you.
KTM520guy said:
The drill you have is threaded 5/16-24 (I think). One size up from 1/4-28. .
The thread looks to be the same 1/4 28. its just the diameter of the threaded end is much bigger.
\\\\\ This is the normal size
\\\\\\\\ This is the end that is bigger / need to reduce.
