I am sloooowly continuing the rehabbing of the RV-3A I bought last summer and have just about fixed all the issues I found with the empenage. The last item I am mulling over is how the original builder routed the elevator trim tab. He ran a 1/4 plastic pipe through the elev. horn shaft and then ran a wire through that hooked up wheel a wheel on the left side of the cockpit. A problem I have with this installation is that at certain points of elevator movement the trim tab wire gets a bit tight and won't easily allow tab adjustment.
I was wondering if anyone else has type of arrangement, or if this is unique to this build...
Doug
[https://www.dropbox.com/s/ivq3c880qcqvjgh/Trim tab wire.jpg?m]
Doug
