I keep thinking ahead about the airworthiness inspection. Right now I wondered about the aft wall closure in the baggage compartment. You cannot get all the screws in/out if the fuel tank is installed. If the DAR wants to see behind the baggage aft wall the fuel tank will have to be removed. While there isn't much back there, if there's a Dynon roll servo there, it is likely that would have to be looked at, meaning the fuel tank would have to be removed so the aft baggage wall cover could be removed.
Alone that's not big deal except if you have gas in the tank; that's probable since most of us would have run the engine and did some taxi work prior to the inspection. Draining the fuel is a real mess.
How did you folks handle this?
