Aerosport1
I am in the process of installing my windows in the doors and the windows are .165 to .1875 thick and do not fit the window channel. They are almost .04 to .060 to thick. It seems that these should be the same thickness as the rear windows which were .120 to .140. Has anyone else had this issue? If I try to sand down the shelf the window sits on I will sand almost or will go through the external door skin. At this thickness
there would be no good way to blend these into the outer door skins.
Has anyone else had this problem?
Geoff
N829GW
Geoff
N829GW
