Hello all, I’m working on wiring the FWF stuff. From what I’ve been seeing, it doesn’t seem like a lot of the thermocouple extension wire out there is shielded. Seems like the engine compartment would be an electrically noisy place with alternators and ignition systems, and thermocouples run down in the micro volt range IIRC. Have people been using shielded thermocouple wire, and if so where do you buy it?
Chances are I’m uninformed about something, so if there is no shielding, can someone explain why?
Sam
Sam
