I don't see anywhere in the Garmin docs, or Alcor sheet that came with the engine kit about attaching the probe wire to the thermocouple extension wire.
Since the probes come with a ring terminal I'm guessing the best way to terminate is like terminations screwed together.
I don't see anything like Alumel/chromel ring terminals readily available.
As a sanity check just want to confirm that using a quality Amp ring terminal on both extension wires cancels out the error introduced and no one has seen issues with this type of installation. I see Aeroelectric did an alternate method using crimp Pin/Socket.
Thanks for the insight from the masses.
