Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
DA2000
bobhope2505
dr
Bob Y
Spotlighted Classified
Mothership
www.vansaircraft.com
RE: Hey, want to see a video of a sick ROTAX 912iS?
…Tony Kirk
There are two Crankshaft Position Sensors, they are on the left rear of the engine. You need to check that you reinstalled the connectors to the proper sensor.
RE: I need some help planning a fuel return for my qb wings
…planenutz
Similar to Ralph, I ran the return -6 aluminium tube from the right side of the firewall, vertically down the side then aft. Iused a bulkhead fitting in the side skin pentration and in the tank Iplaced the bulkhead fitting aft of the forward tank/fuse attachment and forward of the tank cover-plate. The connection between the fuselge and the tank was made un a "u"shape so that there was as little stress on the tube as possible and for saftey in an accident.
OFF TOPIC:
v/r,dr
DA2000
Back in the Game
Hello VAF, Just picked up a flying RV-7. Previously owned 2 RV-4’s with my father 2002-2016. My son’s chipped in a third each on this one. Should be fun! They start checkouts today.
www.vansairforce.net
bobhope2505
N144SD post crash rebuild - don’t judge a dent by its cover.
In the first photo you see a leading edge rib that was pulled out of a badly damaged wing. In the second photo you see what looks like very minor damage to the wing skin. In fact, this was overlooked until the wing was on the table and cleaned off. In the last photo you see what I found when I...
vansairforce.net
dr
Dynamic Procedures: The future of instrument flying (video of webinar yesterday)
[ed. Screengrab from my iPad below the embedded vid. My part time gig at the sim just got easier (fewer screen changes - faster changes of approaches). v/r,dr] Introducing Dynamic Procedures, a new way to view, brief, and fly instrument approach procedures in ForeFlight. Access all of the...
vansairforce.net
Bob Y
RV-12iS Fuel Pumps Not Automatically Shutting Down After Engine Shutdown
After getting nowhere with Van's support on this subject (they wanted me to tell them how the fuel pumps shut off), I'll reach out to the group to see if any other 12iS owners have experienced their fuel pumps continuing to run after engine shutdown. Yes, I have implemented SB-00058 for the new...
vansairforce.net
New Sensenich Propeller.
This Senenich Propeller , Model 70-79 has been run for 31 hr. on my brand new RV4. 160hp. The prop is in perfect condition as you can see in the pictures. I am including a Senenich metal 13" spinner, painted black, a 2.25 spacer, and 7/16" hardware. Price is 4,850. I will box up and ship to...
vansairforce.net
Mothership
Demo an RV - Van's Aircraft Total Performance RV Kit Planes
Experience the RV Difference RV demo flights are available at our factory in Aurora, Oregon—weather and aircraft availability permitting. And while you’re here, don’t miss our factory tours, held daily at 1:00 PM, Monday through Friday (excluding holidays). It’s the perfect opportunity to...
…Tony Kirk
Following up on the great fuel leak of 2025, everything is fixed so I figured I'd try to start the Rotax 912iS for another "first engine start" attempt. I didn't expect much; I didn't get much. I did three attempts; none of them were very good with an inability develop any power. A later...
vansairforce.net
…planenutz
I would like to install a fuel return line in my quick build wings and was wondering if anyone has any advice on the installation. Pictures would be helpful. Also what parts would I need at the fuel tank. Best location to drill the hole? Any other advice? Thanks! Dan
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
