Coleman’s refurbished RV-6 is getting close to flight with its new panel, mags, prop, etc. I took some pics today. dr
![Screenshot 2024-07-10 at 4.27.12 PM.png Screenshot 2024-07-10 at 4.27.12 PM.png](https://vansairforce.net/data/attachments/44/44834-b4da10d2a9225aac129ec04dc4ddd30f.jpg)
![Screenshot 2024-07-10 at 4.27.22 PM.png Screenshot 2024-07-10 at 4.27.22 PM.png](https://vansairforce.net/data/attachments/44/44835-607aa07ac785a8555227a1a59f9d59ae.jpg)
![Screenshot 2024-07-10 at 4.27.42 PM.png Screenshot 2024-07-10 at 4.27.42 PM.png](https://vansairforce.net/data/attachments/44/44836-983fafbea87b22640611cf7541c4a983.jpg)
RV News That Caught My Eye Over The Last Few Hours ….dr
__________________________
Reminder, Brad from Garmin will have a kiosk at 52F Fri from 9-11.
www.vansairforce.net
Aileron - section 21-09 step 2 mistake
vansairforce.net
![Screenshot 2024-07-10 at 4.34.50 PM.png Screenshot 2024-07-10 at 4.34.50 PM.png](https://vansairforce.net/data/attachments/44/44833-cd5e22739745973ec3969a57d4427984.jpg)
GMU-11 Question
I’m doing the same thing with my RV-4 except that I have the mounting bracket from Stein.
The wires for the trim servo & the tail light (uAvionix TailBeacon) will run right under the GMU-11.
I’m concerned about possible interference. What do you guys think….YES or No.
vansairforce.net
![Screenshot 2024-07-10 at 4.39.11 PM.png Screenshot 2024-07-10 at 4.39.11 PM.png](https://vansairforce.net/data/attachments/44/44832-2ccb14502b484873153b028fcf124805.jpg)
Wirejock’s Louver Setup
FWIW. I added blast gates to my louvers. They are only ground adjustable. Blast gates are several layers of fiberglass, slotted for the screws. Nutplates in the louvers inside. Loosen screws. Take a pick and slide the gate open or closed. Tighten the screws. Very little weight gain.
vansairforce.net
![Screenshot 2024-07-10 at 4.41.05 PM.png Screenshot 2024-07-10 at 4.41.05 PM.png](https://vansairforce.net/data/attachments/44/44831-d9a43d586744654ff6ce9b9b399a82af.jpg)
OSH RV Events Info:
OFF TOPIC:
![IMG_4661.JPG IMG_4661.JPG](https://vansairforce.net/data/attachments/44/44830-debf32b401b1bdfc127cae3d638b9f73.jpg)
PS: Older issues of the ‘VAF News’ can be found at:
Come play w/Garmin avionics kiosk at my home field this Friday! (52F)
If you would like to play around with Garmin avionics in a kiosk similar to what will it be at Oshkosh, with no crowds around and with a factory rep there to answer your questions one on one, stop by the location listed below between the hours of 9 AM and 11 AM this coming Friday, July 12. From...
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
I was congratulating my self on riveting the aileron bottom skin all by myself (way to go!) and had blind riveted one of the main ribs. I turned the aileron around to rivet the other rib and see that the overlap was incorrect (aw shoot…). Lots of rivets to drill out if this needs to change...
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
GMU-11 Question
GMU-11 Installation Location?
Hi, After lurking here for at least a decade, I recently purchased a flying RV-7A with a steam-gauge "4-pack" (no AI or DG) & TruTrak Vision AP. I'm planning to install a pair of G5s & a GMU-11 for now, with plans to move to a G3X panel later. I've searched the forums, but haven't located...
Cowl Flaps?
I'm contemplating installing an Anti-Splat cowl flap and I'm looking for installation advice. I have (I believe) a problem with engine compartment temps, which are creating problems under the cowl: hard restarts when hot variable fuel pressures when taxiing premature failure of red cube...
OSH RV Events Info:
The OSH’24 RV Events ….summarized in one spot.
Added here up top as I get them - a thread where OSH’24 RV activities can be summarized in one spot. If your RV group has an event you would like me to add to this list, just add a reply to this thread and I'll add a bullet point here in the first post. If you have an event that is going to...
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
