RV News That Caught My Eye ….dr
__________________________
What did you do w/your RV this weekend? (June 1-2, 2024)
vansairforce.net
![Screenshot 2024-06-02 at 9.12.50 AM.png Screenshot 2024-06-02 at 9.12.50 AM.png](https://vansairforce.net/data/attachments/42/42535-4b3350e8a4532d1dbefdb002353c6477.jpg)
![Screenshot 2024-06-02 at 9.13.04 AM.png Screenshot 2024-06-02 at 9.13.04 AM.png](https://vansairforce.net/data/attachments/42/42536-14b0620e7c1c2f0e93f6b732a636b43d.jpg)
Engine won't start (anymore)!
vansairforce.net
CSK Instrument Panel Flange Doubler …-14 TASEsq
To close off on this thread, i ended up dimpling the F-1467A angle pieces with sub-structure dies, and dimpled the F-1467B flange doubler with normal dies. Had to upsize the rivets to -3.5. All nested nicely and was a lot quicker and easier than countersinking in my personal opinion.
Prior to painting in the cockpit color, I had to cleco it into the fuse for the money shot.
https://vansairforce.net/threads/csk-instrument-panel-flange-doubler.227106
![Screenshot 2024-06-02 at 9.15.01 AM.png Screenshot 2024-06-02 at 9.15.01 AM.png](https://vansairforce.net/data/attachments/42/42534-201472b590feee6055ab61ddfc7bbbf2.jpg)
FF-01226A Missing Hole …12
vansairforce.net
![Screenshot 2024-06-02 at 9.17.29 AM.png Screenshot 2024-06-02 at 9.17.29 AM.png](https://vansairforce.net/data/attachments/42/42533-36b7822daa976bae15ba138666228568.jpg)
Fuel tank vacuum for repairing outside seam…Jesse23 update
Gonna try from the outside 1st. It’s weeping and not dripping, but small band aid before pulling the tank. I also removed the nut plate under the fuel line to make the sealant work easier. Will report after a week of dry time.
vansairforce.net
![Screenshot 2024-06-02 at 9.19.50 AM.png Screenshot 2024-06-02 at 9.19.50 AM.png](https://vansairforce.net/data/attachments/42/42532-5f9f68634a57b99050fe4ae174ee6271.jpg)
Interesting find today
www.vansairforce.net
![Screenshot 2024-06-02 at 6.51.24 PM.png Screenshot 2024-06-02 at 6.51.24 PM.png](https://vansairforce.net/data/attachments/42/42530-6758c58f161a1c4ee5ecdc882d35cb71.jpg)
OFF TOPIC:
![IMG_4202.JPG IMG_4202.JPG](https://vansairforce.net/data/attachments/42/42529-cd1e5e0e61a296c8a8c12787d0a64eee.jpg)
PS: Older issues of the ‘VAF News’ can be found at:
...getting this weekend's thread started! v/r,dr
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
UPDATE: was able to do a A/B check with a mag from a friend who just pulled it to install a SureFly .. worked perfectly! I'm going to send in out for IRAN and we'll see what was wrong. I've run into a engine starting issue that I would like your advice on: I no longer can start the engine...
Hi VAF, I am building new carburetor drip trays for my RV-12 because the old ones are corroded and cracking. I got the new parts in from Vans, FF-01226A, FF-01226B, FF-01226C, and FF-01226D. The relevant KAI section is 46-06. The picture in the KAI depicts three holes in one of the areas of the...
Trying to use vacuum to suck in small amount of pro seal (Flamemaster) on bottom inboard flange near drain valve. It doesn’t drip, but starts staining the seam, and I wipe off after each flight. I also noticed the bead of sealant is very gummy on the outside of the seam in that area, when the...
I'm doing my condition inspection and the intake valve on #4 cylinder apparently has an issue. Compression on that cylinder went from 78# to 74# in the last 18 hours and when borescoped it has a definite hot spot. I really don't want to pull the cylinder unless necessary so what should be my...
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
