The VAF News - 6.25.2024. #6113. New SB on RV-12. Control Stick Pushrod Inspection (before further flight)
RV News That Caught My Eye Over The Last Few Hours ….dr
__________________________
Published: SB-00102 - Control Stick Pushrod Inspection (before further flight) …RV-12
This service document directs owners/operators to inspect flying aircraft before further flight. Van’s Aircraft has recently become aware of an EAB RV-12 where it appears that the pilot’s side control stick became disconnected in flight due to improper assembly of the F-1264 Control Stick Pushrod Assembly. Out of an abundance of caution this service bulletin requires an inspection of the F-1264 Control Stick Pushrod Assembly, the correct installation of jam nuts, and proper orientation of rod end fittings.
KAI 11-02 (rev 1), rod end bearing adjustment questions
Cylinder Solvent Flush Candidate?
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
