The VAF News - 6.10.2025. #6358.
DeltaRomeo
doug reeves: unfluencer
Staff member
DanH
Archie167
After some more advice on the next stage of my project. Have an A1B6 that’s been bulk stripped for IRAN and I need to convert to 12V set up. I will order a Hartzell constant speed prop (C2YR-1BFP/F7497-2 ,72 in. dia) from Vans but the ignition set up may influence that - not sure? So my queries:
1. Alternator. I have a PP/Hartzell AL12-E60/B that came with the FF kit but I believe having read another post this may not be the best one to use which is frustrating becomes it becomes a large and expensive paper weight. A friend of mine also had one that failed inflight. His suggestion is a B&C with external voltage regulator. Thoughts?
2. Starter Motor? Any recommendations appreciated.
3. Ignition system. Existing magentos will need to be switched out I assume being currently a 24V system. Interested in electronic ignition but there’s pro and cons and I’d prefer not to run a second battery as backup. Interested to learn some opinions or experiences with this.
4, anything else I haven’t considered?
Update: RV-6A Very Slow Build, Western Australia
I'm continuing on with the remaining "1% work" final assembly and have so far fitted the wing fuel tanks and connected their lines, as well as the ailerons, the Flyleds wig-wag landing lights and the wing tips. The control columns and main pushrods have been installed and the elevators are mounted on the horizontal stabilizer.
RE: Slider canopy stop / latch …alpinelakespilot2000
Agree, great solution. Even found a pre-threaded 2” aluminum binding post in the hardware drawers at both my local Ace and TrueValue stores. Ended up being a 30 minute project. Thanks for the idea!
RE: Rudder bottom fairing interference with VS bolts …bjdecker
Concur with @D-Dubya, bolts are too long.
Attached from the -7A, but you get the idea. The 6A tail tie down must be different. For the -7A, Van's created a new part (F-712E) that sits on the forward side, catches 4 bolts, all AN3-6A's, etc..etc...
OFF TOPIC:
