The VAF News - 5.29.2024. #6094. Rain, RV Social, DIY VOR Ant., Panel Upgrade, Engine Failure (fuel)
As I laid down to go to sleep Monday night, I was thinking I *might* go for a short RV flight the next morning to go inspect some of the recent tornado damage, if the WX was VFR. Around 5 AM it started raining. By 6 it was raining really really hard. A little after seven it was obvious I was gonna have to drive Susie up to her volunteer gig at the hospital. We counted 25 trees cracked or tumped over.
This is what the airport looked like. I need to cross this taxiway and I have brand new grease in those mains. So I worked on the car. Finally got the remanufactured starter in the 17 yr old Accord. Good to go!
dr
RV News That Caught My Eye ….dr
DIY VOR Antennae: Carl Froehlich
“…On four RVs I built a standard wingtip antenna out of aluminum from the scrap box, some fiberglass to make the Gama Match, and perhaps $3 of specialty hardware. It works outside 100nmi for VOR reception, and LOC/GS far beyond useable range.”
I finished my panel upgrade.
2024 Oshkosh RV Social is ON
PSA: Ensure fuel filtering between tanks and Red Cube fuel flow transducer
Control Cable Clearance RV-14 (Mixture)
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
