RV News That Caught My Eye ...dr
What did you do w/your RV last weekend?
vansairforce.net
![Screenshot 2024-05-27 at 4.23.00 PM.png Screenshot 2024-05-27 at 4.23.00 PM.png](https://vansairforce.net/data/attachments/42/42109-c8fa6a0f211b648653dbc330c97369d3.jpg)
RE: Frustrated with low fuel fuel pressure readings. Carbureted 0360
Here is my install of my minor alteration.
I needed a 12vdc supply for my iPad where I receive my ADSB in and ForeFlight information.
items used: gauge is non liquid filled., phoenix stainless braided line and fittings, AN4 bulkhead fitting / on firewall.
results: start up = 6 to 7 psi.
cruise at 5,500’ = 3 to 3.5 psi.
im not sure if altitude has a way of reducing the gauge readings?
vansairforce.net
![Screenshot 2024-05-27 at 4.26.42 PM.png Screenshot 2024-05-27 at 4.26.42 PM.png](https://vansairforce.net/data/attachments/42/42110-a22a0a8fe2c477de8b472190ff117d45.jpg)
RE: Seriously stuck due to wing bolts …DanH reply
Do you have a little space under the head? If so, protect the spar box with an appropriately sized and padded steel or aluminum plate and insert the tip of a pry bar under the edge of the head. I'm talking about a bar two feet long, or more. Lube the bolt as described above, ply out a little, stack another fulcrum plate, repeat. Eventually you'll be able to substitute a wood block for the plates. I plan to make a bar with a forked tip before I do the next one.
Along the same lines, making up a drift with a L-shaped foot may be worthwhile, just so you can bump the pin back a 1/2" or so.
Illustrations for those lucky TW guys who have not had the pleasure. The problem is the two big bolts in the bottom, the threaded end being hidden behind the gear leg socket.
https://vansairforce.net/threads/seriously-stuck-due-to-wing-bolts.227159/post-1770683
![Screenshot 2024-05-27 at 4.27.38 PM.png Screenshot 2024-05-27 at 4.27.38 PM.png](https://vansairforce.net/data/attachments/42/42111-cac44304dd1ef3664b189eb795658daf.jpg)
![Screenshot 2024-05-27 at 4.27.44 PM.png Screenshot 2024-05-27 at 4.27.44 PM.png](https://vansairforce.net/data/attachments/42/42112-3fcbeeec80b0d6119a5012a90143a1a2.jpg)
CSK Instrument Panel Flange Doubler
vansairforce.net
![Screenshot 2024-05-27 at 4.28.24 PM.png Screenshot 2024-05-27 at 4.28.24 PM.png](https://vansairforce.net/data/attachments/42/42113-0ad5463315120b1dcfcac372cab56297.jpg)
OFF TOPIC:
![IMG_4240.JPG IMG_4240.JPG](https://vansairforce.net/data/attachments/42/42114-44a83e626d44f4b106aa8170ee8dbea1.jpg)
PS: Older issues of the ‘VAF News’ can be found at:
www.vansairforce.net
What did you do with your RV this weekend? (Memorial Day 2024)
… getting it started v/r,dr
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
My experience has taken 2 years approximately 180 flight hours. equipment is GRT EIS 4000 indicating system. Carbureted 0360 direct pressure gauge reading on ground = 5psi engine driven pump and 6psi with engine running and electric pump on. problem; minimum fuel pressure exceeded. Although...
On page 35-13 the instructions call to countersink the 0.032” thick F-01467B Instrument Panel Flange Doubler. Has anyone dimpled this instead? (Including dimpling the underlying flange parts?) I’m wondering why they would call to countersink this part. I do vaguely recall this being...
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
