Wishing you and yours a happy, safe and RV-filled weekend!
v/r,dr
RE Inspection Covers
…KazooRV-9A
I used the Cth6 method. Thin rubber sheet from Amazon. Traced around the panel and cut out the middle. Used 3M weather strip adhesive with a weight on the panel till it cured and trimmed around it. Heated a nail to poke the fastener holes open. It installed pretty well and was very simple to do.
David Paule 3B FAB Update
After some fuss and bother, I finally got the FAB together. The somewhat oversized flapper valve works and seals both closed and open.
Carsten (I’m New Here)
RE RV-6 Glareshield.
…rv6n6r Here's a pic of my set-up, just clears the top cowl. RAMI antenna driving WAAS GPS and ADS-B, barely showing beyond that it is a second remote GPS ant. for the handheld.
https://vansairforce.net/threads/rv-6-glareshield.233423/post-1828285
ELT Mount Fabbed Out of Scrap
…JeremyL
OFF TOPIC:
v/r,dr
…KazooRV-9A
How to seal inspection covers
I’ve installed these Van’s upper cowl inspection openings. What is a good way to seal them?
vansairforce.net
RV-3B Dave's in Colorado
Just a note to say that the surgery seems to have done what it was supposed to Stay tuned to this station! Dave Great news!! :D
vansairforce.net
High EGT's and CHT's
I'm experiencing high CHT's and EGT's during climb-out, which I have not noticed before. Two days ago I did a test-flight to record engine data on my GRT Horizon HS, and was able to open the files and read it last night. I am looking for suggestions as to the cause of the high temps. Here's the...
www.vansairforce.net
…JeremyL
ELT mount technique
I installed my ELT (I can move it if necessary) 90 degrees from the instruction recommendation. Can anyone tell me why I wouldn’t want this spot? Seems to fit perfectly and is out of the way of any cables.
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
