Wishing you and yours a happy, safe and RV-filled weekend. Thanks again to those who Account Upgrade w/a badge and keep the lights on here. You badge-sporting awesomes make the site. Have a wonderful weekend.
v/r,dr
VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
Seen in another post….ATIS reminder
Pretty dang cool. dr
High EGT one cylinder
IO-390 A3B6 800 hrs: Noticed high EGT on #3 at T/O today. Also substantial increase in CHT. so downloaded the graph
Runup and mag checks ok. Inflight mag check also showed no odd behavior.
Any suggestions on further diagnostics?
STUPID mistake: closed canopy with no one inside
The nightmarish scenario is happening now . I closed my tip up canopy and the lock got engaged . Urghhh!!!! I saw a post of how someone had the same issue and solved , however the pictures got removed because of old post . I have a slot opening on left side because I installed jdair custom canopy lock , so I can fit a contraption through that . Any help on this is appreciated.
Some color finally …Jack -12
Finally got to apply vinyl stripes using knifeless tape. The rudder is painted. This is my first time using vinyl.
Advice & words of wisdom for a new RV-7A owner
Looking for some advice and or words of wisdom or something you wish you had known before you bought (or started flying) your RV7. Just some background, I am coming out of an RV12iS partnership and my co-owner in the 7A has never owned a plane before.
Flap Extension Labels …Daida PIREP
Works like charme!
Never fails or breaks
Easy and cheap to put on/replace
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
v/r,dr
IO-390 A3B6 800 hrs: Noticed high EGT on #3 at T/O today. Also substantial increase in CHT. so downloaded the graph Runup and mag checks ok. Inflight mag check also showed no odd behavior. Any suggestions on further diagnostics?
vansairforce.net
Hello fellow builders The nightmarish scenario is happening now . I closed my tip up canopy and the lock got engaged . Urghhh!!!! I saw a post of how someone had the same issue and solved , however the pictures got removed because of old post . I have a slot opening on left side because I...
vansairforce.net
Some color finally
vansairforce.net
Hi All, Looking for some advice and or words of wisdom or something you wish you had known before you bought (or started flying) your RV7. Just some background, I am coming out of an RV12iS partnership and my co-owner in the 7A has never owned a plane before. Thanks in advance!
vansairforce.net
Works like charme!
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
www.vansairforce.net
