Landing light connector
I'm wondering how everyone else solved this issue. I know I can choose any order for the pins as long as it matches both the female and male side, but I was wondering if there was any consistent answer on how you all were solving this. I searched the forums and contacted Van's Builder support...
vansairforce.net
Fuselage Hole
There is a gap in the fuselage between where the front side skin and mid side skin meet below and near the leading edge of the wing. What did you do to cover this gap?
www.vansairforce.net
Question about heat shielding front lower cowl
Removed the lower cowl on my RV-9A at 12 hours total flight time. Noted this appearance. Comments on what this discoloration is? Don't see any indication of melting or deformation, on the outside of this area. Should I install heat shield material?
WDYDWYRTW? 11/8-9/2025
What did you do with your RV this weekend? Saturday morning I went out and took the RV up for a spin, as it was the first weekend in eight weeks I didn't have an extra paper route. REALLY nice flying!!! Wasn’t alone - lots of folks getting in some flying before the northern winds arrived mid...
vansairforce.net
I started with the standard cowl on my 9A, got it fitted and didnt like how the hinges came out so I got a James cowl. It was finished better and I was able to pick it up at their shop in Oregon. I have a carb on the bottom O-320 and I was not able to make their cone shaped air filter system work so it was a lot of effort making the standard FAB work. In the end, I am happy with the results. I have a plenum and my temps are great. It looks good and Im sure it is much faster! Ha!
Im sure you will be happy with either choice.
James Aircraft Cowling, Plenum, Induction Inlet
All, Requesting experiences using James Aircraft RV-14 Cowling, Plenum, Induction Inlet. Did you find it worth it? What did you like/dislike?
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
