As you probably guessed we are converting a RV7a into a RV7. This is plane is under constrution, the tail was complete and mounted and the engine was mounted but no hook ups were done. Installing the tail spring took less than a day and the metal parts are out for powder coating but the main work is done. A couple of hours should finish the tail. Removing the engine and old mount went quickly. The new engine mount was bolted to the engine first and then this assembly was mounted to the firewall. This is easier than doing the engine last. Swapping the gear, brakes wheels etc has also been done. The firewall forward part of this job only took 5.5 hours. We have to remove the old gear leg mounts from in front of spar and fill the old gear leg holes.
This is not really that bad a job and the conversion kit that Van supplied was quite complete.
