I flew the repaired RV-12 this morning. After a short flight the Dynon D-180 went nuts and said no oil pressure, so I made an immediate landing.
Subsequent investigation showed oil temp 15-degrees, CHT 10 and 12-degrees, MAP 52.9-inches, fuel pressure 86.1 psi, etc. Next time the unit was powered up things looked fairly normal. Next power down/up things kept changing. Called Dynon and got no tech support...had to leave a message.
Anyhow, plane flew well, no heavy wing, trimed out fine, climbed fine, landing had a lot more float than I like, and handling was fine.
I think there is some 'massive' intermittent in the D-180. Plugs were all pulled and re-seated, etc, with no change.
JohnF
JohnF
