Aluminum versus iron piping
Bob, There are several suppliers of aluminum pipe specifically designed for compressed air systems for home workshops. I considered them for the compressed air system for my workshop I built about a year ago. The pro's are easy installation, ease of takeapart and re-installation, and a neat installation. The con's are cost, kit packaging which may lead to having to buy more than you really need, and cost. Did I say cost?
To me the aluminum was just way too expensive for the installation I planned. After seeing DanH's photo of his shop, and after considering the many carbon steel ("black iron") compressed air systems I had installed as a Facilities Engineer, I decided on carbon steel pipe.
I do have ball valve drains at each drop; for the two drops in the center of my shop, I also tee off the TOP of the main piping run and then go down for each drop; and I have a straight run to the drain valve with the regulator and ball valve in both horizontal runs. My last drop is diagonally across the workshop and I have a ball valve located about 4 feet off the floor to drain any moisture. I have an automatic moisture drain on the bottom of my tank that drains condensate each time the compressor starts (got it at Harbor Freight, and so far it's worked great!). When I leave the shop I close the main valve just downstream of the main tank, and then when I come back to the shop I open valves in a set sequence to be sure and drain any moisture that might be present. So far, I've caught very little. It sounds more complicated that it really is.
Carbon steel pipe isn't really hard to work with and the cost is reasonable, once you invest in a pipe threading die.
One other comment...we engineers tend to think a lot and not get much actual work done out in the shop. However, with a little forethought and planning, an adequate compressed air system can be installed.
I do admit to having Sch 40 PVC piping in my previous garage/workshop and after learning of the POSSIBILITY of plastic shards being propelled in all directions, I decided to take it out and not repeat it in my new shop. I don't intend to start a new pipe war; it's already been debated enough. The clincher for me was I could not find a single piping code in the U.S. that allowed PVC for compressed air, except one...and that one allowed it buried 18 inches underground.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There's some concern that the small amounts of oil that inevitably come from the air compressor may cause deterioration of the PVC over time. How much time? Maybe several years. I didn't want to be a test case. Plus, if I ever sell my house, I didn't want the possible liability of a PVC air system in the shop.
More than you asked for, I know, Bob, but I was going to post anyway and just decided to include all this in one post.
Got to go get something done on my rudder out in the shop!
Don Hull, P.E.
