Well it happens to the best of us, my time in the garage ended today with "that was expensive". I was working on the left elevator. bending the edge where the trim tab goes. I got the bend to far outboard and tore the skin a little bit. right there I knew I was probably done. however, in an attempt to save it I stop-drilled the tear and acctually got it looking pretty good, sure there would be a little bigger gap but I'm not building a show plane. Then the nail in the coffin was when i put in the 609pp spar and it was too narrow because the trailing edge bend was too wide. Call to van's on monday will get the new parts on my way, hope its not too expensive.
Question, would you drill out the stiffeners or just order those too?
Building planes is fun![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
