Can I safely test the starter if I have the necessary clearance around the prop in the shop. I'd like to pull the top plugs and just quickly test the starter under a small load to ensrue everything works before taking it out to the airport.
Jim, I turned mine over much the same way. First I turned the prop by hand to pre oil the engine, then cranked it with the starter. I used mine to get oil pressure. It won't be much of a load on your starter. With the plugs out, it will blow your hair...................I said your hair........not mine, mine has long gone down the drain
