Brantel
After spending about 4 hours building a beautiful harness for my new PM3000, I fired that puppy up last evening and found what several have reported and that is a high level of WHITE NOISE in the headsets.
Now I know all the discussion about you will never hear it when in the air with the motor running, I would most likely agree with that statement but the noise there does seem to be excessive.
Lets get a few things out of the way so this does not turn into a bunch of replies for troubleshooting:
1. Power supply is a clean variable bench model that was set at 14vDC
2. Harness was built by me and is a work of art and is exactly per the wiring diagram.
3. The jacks are isolated from the aircraft (not even mounted in the panel yet)
4. Proper cable shield treatment has been followed.
5. The noise is not ground loop noise, not 60hz hum, it is plain old white noise.
6. Everything else about the intercom works like a charm.
7. The noise is not affected by the squelch or the volume control, the noise is a constant level out of the intercom.
8. Headsets are Lightspeed passive mono/stero and they work in either mode and the noise is there regardles of mode. The headset volume control reduces the noise but also reduces the intercom volume.
9. It appears that the preamp's inside this box are amplifying the noise and there is nothing an end user could do to stop this.
I know Mark visits here and will respond, looks like my issue with the noise is considered within their quality standards from the post in history so I am not sure what could be done about it.
That being said, I am willing to wait and see how it works in the air. I don't like that as soon as I turn on my avionics my passengers will be greeted with a earfull of hiss but guess I will have to live with it.
I will try the suggestion I read about reducing the headset volume using the headset volume controls and increasing the intercome/radio volume to offset the noise floor more below the desired signals.
While not a intercom circuit expert, I am an electrical engineer with a degree in electronics. I have a working knowledge of how audio circuits work. I have also served as an audio engineer within my church so I understand issues that can exist in audio systems.
I was aware that some have reported this with the PM3000, but I decided to give PS Engineering my business if for nothing more than the fact that they are a local company for me and for the most part seem to have a good record of customer service as recorded here in the archives.
Do the other PS Eng audio panels have this issue? Does anyone using a PM3000 not have white noise?
At this point I am on the fence about if I would recommend this intercom to someone in the future or not. I will have to try it in real life for a while to make that determination.
PS: If you want to hear what I am experiencing, go here for a listen...
