Testing Mag Wiring
Jim P
I'm in the process of wiring my Slick mags and have the 18 AWG shielded wire connected to the mag. Center conductor goes to p-lead, shield goes to mag ground stud.
Now for the really dumb question; how in the world do I test the wiring for the mag? I thought if I went tested resistance between p-lead to ground, it would show good connectivity with toggle switch OFF. Well, it shows the same with both ON and OFF. Matter of fact, I have good connectivity between p-lead and ground on the un-wired mag as well.
Any help?
You must test your wiring with it disconnected from the mag. If the points in the mag are closed, it will show a closed circuit regardless of the switch position.
Disconnect only the P-lead
The best way would be to just disconnect the P-lead at the magneto ....then use an ohmmeter to check for continuity from the P-lead magneto wire end to the magneto ground terminal.
A short is safe, i.e. magneto OFF.
An open circuit is magneto ON.
Just an expansion of what Mel said....
gil A
