Steve A
RV Guru's,
I have plumbed in my fuel system to my Lyc. IO 360 and tested the flow this weekend. First I took a hose from the connection just past fuel pump to a gas can, turned on my electric fuel pump. I recorded 30 gal per hour on my Grand Rapids EIS. I had a minor fuel leak which I corrected. Then I connected my hose to the mixture/throttle control body and disconnected the hose from the distribution center on top of the engine and hooked up a 1/4 aluminum tubing system to the gas can. With the electric fuel pump on and fuel running through the engine driven fuel pump, into the throttle body and then up and back down to the gas can, I only saw 6 gallons per hour on the EIS. My question is, are these values in the ball park or do I have an obstruction. I have not calibrated the EIS as to fuel flow. I assume with the engine running and pulling fuel through the system, the fuel flow will be much higher.
Sleepless in Louisiana
RV 7A finishing perpetually
