lndwarrior
Engine is an O-235-C1 and the CHT's have always been very stable. CHT monitors all 4 cylinders (MGL unit). The sensors are under-the-spark-plug type.
Towards the end of a 90 minute flight the MGL warning light comes on and the #3 CHT reading is rapidly cycling. The cycling is so fast its hard to read the numbers.
I have the warning light limit set at 400 degrees and I think I saw a 400 number at one point. I was just about to enter the pattern at this point and throttled down. Almost immediately the #3 cht returned to a stable 320 degrees, which is normal for this engine. Other chts remained unchanged and stable while this happened. EGT's were all in the normal range when this happened as well.
Also, no loss of power or engine roughness.
The fact that the reading on the cylinder was cycling so fast you could barely read it is what surprised me. This was not the normal change rate at all.
Any ideas where I should start to investigate this?
I will check the wiring connections and pull the plugs on the cylinder.
TIA
Gary
TIA
Gary
