Toobuilder
I have a situation with temperatures that I don't understand and was wondering if any of you have run across the same thing. I have found that the CHT and EGT can be managed very easily at relatively low altitude by running LOP. If the CHT starts to get away from me, I simply lean it a little more and can get it right down to where I want it. Since I have dual electronic ignition, I can lean to 100+ cooler than peak or more with the engine still running smoothly. The problem I am having is the higher in altitude I go, the more the engine splits in EGT and CHT. 1 and 3 respond together, as do 2 and 4, but the temp split between the two sides of the engine gets quite wide with altitude. What this means is that if I'm trying to bring my hottest cylinder under control by leaning, my coldest cylinder is already way too cold and gets worse with every turn of the mixture knob.
Notice the major spread in CHT and EGT between the left and right side of the engine in this picture at high altitude. Trying to lean further to bring #3 under control would cause the already too cold #4 to plummet further.
Now, here at low altitude, also WOT and LOP, things are much more under control. The temperature split between EGT is very narrow, and CHT are nice and cool. This is what I want it to look like at altitude!
This is a 200 HP (angle valve) IO-360, Bendix FI with a standard Vans cowl, and baffles are new and sealing against the cowl. Also, the "tape over the cowl split" trick did not seem to make any difference.
So does anyone have any theories why I get this split with altitude, and more importantly, how do I fix it?
Thanks.
![xmtt03.jpg](/proxy.php?image=http%3A%2F%2Fi56.tinypic.com%2Fxmtt03.jpg&hash=840c602a39e12eef42f885c3f79c81e7)
![14jn76u.jpg](/proxy.php?image=http%3A%2F%2Fi53.tinypic.com%2F14jn76u.jpg&hash=803a31ff5c721f9c84245f0d200e859f)
Thanks.
