I have an Infinity stick grip with a momentary flap-down switch; and a continuous flap-up switch. I also have the TCW Flap controller which advertises that it is compatible with the Vans flap motor and the Infinity continuous switch in that it will allow the flap motor to run for 12 seconds then shut off. The TCW controller I have actually allows the motor to run for 19.5 seconds and the flap retraction time is around 8+ seconds. The 10+ seconds of the flap motor running against the stop is a concern to me. I don’t know the mechanical characteristics of the flap motor. At first blush you’d think that the gears are grinding away as the flap motor labors against the stop.
I am switching to the momentary up and down switch but I'd like your comments on the issue: real or no.
thanks,
Don
thanks,
Don
