Gaylon
Active Member
RV10, Tapping noise coming from tunnel area when applying Left/Right brake
I have a tapping noise I hear when lightly applying the right (mostly) and left brake. The tapping noise sounds very much like if you where to rattle the "top hat" (WD-1015 Collar Assembly) on the nose gear link assembly. I had this before and after performing SB14-8-29. The tapping rhythm changes with speed and is only noticeable at slow speeds only when taxiing at idle speeds. So it will increase and decrease and almost sounds like a stick in the spoke scenario. Again only if I lightly apply the brake on one side or the other but not when both brakes are applied.
I orginaly thought I had a portion of the Show Planes lower cowling attachment that covers the nose gear area hitting the engine mount frame but I don't believe this to be the case anymore as I have trimmed this area for more clearance.
I did originally have only one washer under the top hat and after the SB added a second washer.. Maybe I need a third but I have no idea how I would fit another on there at this time.
Any suggestions would be appreciated!!
